diffs
diffs
Hi sorting through some of my spares to sell at national day & found a couple of diffs me56205 & me49523 am i right in thinking they come from a mk 2 saloon? not sure of ratios as no paint on driveshafts somebody told me how to work it out once but i cant remember cheers,
Re: diffs
Have a look at this link, I think you have Mk2 2000 Diffs: https://triumph2000register.co.uk/the-c ... fications/
1966 2000 Mk1 Estate - Cherry Red (2.5 PI conversion) SOLD
Re: diffs
ME diffs are definitely from a 2000.
To determine whether they are auto or manual, rotate the output shaft flange (driveshaft flange) one complete revolution, and count the number of turns of the input flange (propshaft flange). If it turns just over 4 complete turns it is a 4.11:1, and if it turns nearly 3 3/4 turns it is a 3.7:1 diff....
Something to mark the rotating flange will help to count the turns more accurately.
3.45 diffs which were fitted to all 2.5 /2500 models irrespective of age / gearbox type had red paint on the large nut in the centre of each output flange.
