2500 Sump
2500 Sump
I'm almost ready to drop a late TR6 engine in my 2000. My question regards the 2500 sump. Is it angled to compensate for the slant of the engine? Putting it another way, can I simply use an early TR6 sump instead of using a 2000 sump and beating reliefs to clear the rod bolts?
Is the only difference between the 2500 & TR6 sumps the position of the drain? I guess the drain was moved on the later TR6
Regards
Todd
United States
67 2000
Soon to have 2.5 w overdrive box
Regards
Todd
United States
67 2000
Re: 2500 Sump
Hi Todd,
I did much the same years ago. Yes, the drain is different on a TR6 engine (at the front I think?), so will need moving. A relatively easy brazing job.
Don't be tempted to try a 2000 sump. With the increased stroke, the big ends will hit the sump pan. Been there and done that!
Re: 2500 Sump
Hiya Mike
So the drain needs to be on the side? And if so, which side? I have several TR6 pans of different years. Seems to me having the drain plug on front/middle vs the left side, more oil would drain from the middle. My current 2000 pan has the drain on the left side.
Witor led me to believe the p/n the TR number for the sump is 307836. This corresponds to an early TR6 sump where the drain is in the middle
Bottom line, can I use a TR6 sump providing I get the drain in the right place? And if so, where should the drain be? Will I need to shim the engine mounts...it's a manual rack?
Todd
Todd
Re: 2500 Sump
Hi Todd,
I think once you've moved the drain, you can use the TR6 sump as-is. I certainly did!
The drain plug is at the same place as on the 2000 sump, LHS, near the front of the lower part of the sump (I think - all from memory). As I recall, there is a flat area there where the saloon drain plug is fitted. When I fitted a TR6 engine to my Mk1 saloon (in about 1979!) I had a local shop remove the plug, block the hole, re-drill a new hole and re-braze the plug back in again.
Re: 2500 Sump
So my 2000 sump has the drain on the LHS rear. I have available an early sump where the drain is front middle or left side rear. Since the engine slants the other way. I would think right side front or rear would be better, by maybe front middle would be ok?
A picture from anyone would be wonderful
Regards
Todd
Regards
Todd
Re: 2500 Sump
You've got me thinking now Todd!
I'll see if I can photograph something, either my current PI or the sump on that TR6 engine (which I still have!)
Re: 2500 Sump
Hi Todd,
I found some images of a TR6 and PI sump but I can't add them at the moment - it looks like the forum has reached it's storage limit!
If you PM me your email address, I'll can send them directly.
Re: 2500 Sump
PM sent
Todd
Todd
Re: 2500 Sump
With any car I've ever owned I drain the oil by jacking it on the side opposite to the drain plug.
Re: 2500 Sump
Same with me.Clifford Pope wrote:With any car I've ever owned I drain the oil by jacking it on the side opposite to the drain plug.
