Automatic gear box seal
Bruce
#1 Post by Bruce »
Is it possible to change the out put seal to the prop shaft without taking the automatic gearbox out . If yes are there any special tools required
harvey
Re: Automatic gear box seal
#2 Post by harvey »
Bruce wrote:Is it possible to change the out put seal to the prop shaft without taking the automatic gearbox out . If yes are there any special tools required
Yes, just prise the old one out and tap a new one in. There are seal remover tools you can but but I've never needed one, I use a screwdriver. Just make sure you dont go too far behind the seal and damage the bearing in the housing. You can remove the tailshaft housing without removing the gearbox if you did find you couldn't get the seal out in-situ.
