MEMBERS ONLY SECTION, CAN YOU SEE IT?!
We have a forum admin issue here.
It would seem that not everyone can see the "members only section" who ought to be able to.
So would EVERYONE please look at the main forum board index, look for the section about halfway down called "All about the Triumph 2000 2500 2.5 Register", you should be able to see two subtopics. First one is "Register issues" second one is "Members only section".
If you cannot see this bit and you are a fully paid up Register member (I shall be checking!) then please post on this thread with your full name and Register membership number. (or you can PM if you prefer to remain anonymous!) and I shall attempt to fix the problem.
It may take some time as I can't change this setting at the moment so I'm waiting for some help from our resident Guru, Mr Walker!!!
Bear with me, but please let me know if you can't see it. It is important as we are going to be posting more Register business items on here that are for members only.
Alan
Alan
red2000chris
Re: MEMBERS ONLY SECTION, CAN YOU SEE IT?!
I cant see the members only bit, just register issues.
Chris Darwent. 7621-04/12.
I cannot see it either, Alan, just the Register Issues.
Dave Boydell, mem.2035.
Can't see it!
5876-11/12
5876-11/12
Chris Saunders
ditto
Chris Saunders
Register Member 7620
YJO584R, Inca "S" Estate
Hi Alan, no i cant see the members only section either!
David Watkins mem no. 5346
Lloydpiestate
i cant see it either alan
lloyd reed member no 4686-03/91
- johnconradlee
I know I used to be able to see it, so I checked and I couldn't see it (which worried me), then I logged in so as to reply to this topic and now magically I can see it.
So basically double check that you're logged in before complaining that you can't see the "members" only section!
Well, I can see both Alan!
As I remember, some time ago, on request, Allen checked against the membership lists and switched forum members to Register members, usually after a prompt email from the member concerned.
All this was some time ago, and as we now have quite a few new members, this has probably fallen down between the cracks. Maybe it's something that could be added to the membership application form? That way, it's highlighted and could be acted upon subsequently .
Mike. (very old and long-standing member!)
I haven't got the "All about the Triumph 2000 2500 2.5 Register" .
Edit - just found it, but at the bottom, not halfway down.
No Members' Section, just Register.
