Track rod ends
Posted: Mon Aug 06, 2012 5:54 pm
by andyborris
What is the difference between PAS and manual track rod ends (apart from the part number ;D).
Is the thread different or perhaps the taper which fits into the steering arm?
Andy
Re: Track rod ends
Posted: Mon Aug 06, 2012 5:57 pm
by tony
P/S one's are bigger. :shock:
Re: Track rod ends
Posted: Mon Aug 06, 2012 6:00 pm
by Charles H
A very good question!! They fit 180 degrees to each other in the standard cars, and I think that the thread on the PAS ones are slightly larger, and the physical size is a little bigger. However, I can also recall someone mentioning that a car had one of each on it! Perhaps the relative position of the taper to the threaded section is different. Anyone enlighten us further?
Re: Track rod ends
Posted: Mon Aug 06, 2012 8:14 pm
by stag andy
Impossible to fit manual track rod ends to pas rack thread size on pas much larger but that is the only difference taper size the same
Re: Track rod ends
Posted: Mon Aug 06, 2012 8:29 pm
by andyborris
Thanks.
Should add that the taper is .1 mm larger on the manual version and the PAS one is longer by 5 mm.
Info from Elbir Automotive, who make the things!
I'm going for a lie down now, that took some serious Googling!
