Page 1 of 2
MK 1 Rear suspension
Posted: Mon Dec 05, 2011 9:49 pm
by andyborris
Would like to convert my MK 1 back to MK 1 trailing arms, anyone got the bits to sell or swap for MK2 parts?
Andy
Re: MK 1 Rear suspension
Posted: Thu Dec 08, 2011 8:39 pm
by twomanytriumphs
Just out of my morbid curiousity for triumphs, Im trying to figure out what the difference between mk1 and mk2 trailing arms are? Thanks Kyle.
Posted: Fri Dec 09, 2011 12:56 am
by James
The flange that the driveshaft attaches to is thicker — I think that's about it.
I am planning to do the same as Andy and convert back to Mk1.
Posted: Fri Dec 09, 2011 4:43 pm
by andyborris
James,
I think between us we're going to push the price of MK1 rear arms up! :D
I've got a set of deep dish steels (14inch) to go on, guess you want to fit big, fat tyres?
Andy
Posted: Fri Dec 09, 2011 8:36 pm
by James
I've actually already got the arms :)
The clearance between tyres and the arches is minimal and I want to use some camber correcting mounts because I am tired of wearing out the insides of the tyres — so I need the space.
Posted: Mon Dec 12, 2011 12:58 pm
by Mike Stevens
I always thought that the Mk2 track was a bit wider - a couple of inches perhaps. I know one bit of the driveshaft (outer probably) is longer and the 'boss' on the swing arm where the brake backplate bolts to is longer on the Mk2.
A few years ago, CW used to sell a 'kit' to convert from Mk1 to Mk2. If only you could find the discarded bits..... :)
Posted: Mon Dec 12, 2011 4:45 pm
by Alec
Hello Mike,
yes, you are quite right.
Posted: Tue Dec 13, 2011 12:38 pm
by Mike Stevens
Alec wrote:yes, you are quite right
Hi Alec,
I thought that was the case. I remember CW's advert when he showed 'before' and 'after' photos of a Mk1 rear. However, it was some time ago and the memory sure fades these days!
Thanks for the confirmation!
cheers,
Posted: Tue Dec 13, 2011 9:34 pm
by Dave B
The mk1 track width is narrower than the mk2 by at least a couple of inches, as I discovered about 30 yrs ago when I swapped an outer driveshaft from a mk1 onto my mk2 PI, and found that the driveshaft splines only mated for about threequarters of an inch !
The swinging arms and the outer driveshafts are different on each model, everthing else is the same
Posted: Wed Dec 14, 2011 6:54 am
by Alec
Hello Dave,
there is one other difference, the handbrake cable on the MK 2 is longer to allow for the longer track. I forget now if it is the first or second one, but would guess the second one?
