Subframe rear mounts
Re: Subframe rear mounts
#11 Post by simon.williams »
Thank you Johnny, that is very helpful.
johnfrancis898
#12 Post by johnfrancis898 »
Hi Simon
I’ve used Plumbers Mait as a good sealant for these jobs. It’s a non setting type of putty very similar to the what was originally used around the top of struts. I used it when I renewed the front struts on my car and it done the job perfectly. It’s available from your local plumbing shop or Screwfix & Tool Station. It lasts well so you’ll find it won’t go to waste! There are also similar alternatives available.
Rgds John
Member no. 7941.
#13 Post by simon.williams »
Thanks John
