Hello Brian,
I'm surprised that Morris oils are not easily found in your area seeing as their headquarters are relatively close to you? It's everywhere around here?
Engine Oil
Re: Engine Oil
- Allen Walker
Re: Engine Oil
I got a pack of Penrite for the RBRR and, though expensive, seemed to maintain a nicer consistency than my usual Halfords/Comma Classic.
Allen Walker
Hoole, Chester[/size]
Used to have a 1976 Triumph 2500S Saloon in BRG
Re: Engine Oil
As well as additive packages, I think the API and ACEA tests also include performance of the oil at high temperature etc?
I have heard that SF graded oil is the maximum which should be used in old engines as anything higher has additive packages which don't agree so well with old cars.
It could be my imagination but the 2000 certainly sounds and feels more silky with the new oil.
http://www.unitedoil.com.au/apiclass.htm
Re: Engine Oil
Most ,if not all brands that you mention are unavailable in NZ .How about Castrol GTX ?
Having read this thread a bit concerned about the oils I'm using. Thanks Tony.
- Brian
Re: Engine Oil
Hi Alec,Alec wrote:Hello Brian,
I have only found one place where I can buy Morris' oil...surprising as you say as it is made locally!
Brian
Stanley Unwin\'s 1968 MK1 2000 Slate Grey
<br>1972 MK2 PI Estate Mallard
<br>1978 Stag (daily driver) Russet Brown
- Jonathan Lewis
Re: Engine Oil
For anyone in / close to the West Midlands, I'm pretty sure that SNG Barratt of Bridgnorth carry Morris Golden Film 20/50.
After a fair bit of experimentation, I've settled on Penrite HPR30 but again, not always the easiest brand to find outside specialist retailers.
Jonathan Lewis
2.5PI Mk2
2.5PI Mk2
