Mike
Your Blog shows that you may need some door check straps, estate door closing plate and a plenum chamber grille. I should be able to find these parts in my stock of second hand spares. Let me know if you want me to look them out for you and I will gladly donate them to your project.
Parts give away
Re: Parts give away
Re: Parts give away
Thtas very kind of you, thank you. I have now got hold of the front door straps and the door closing plates, so I'd be grateful for 2 rear door checkstraps and a plenum chamber grillCharles H wrote:Mike
rgds
mike
FF Stag V8 Estate White
TR5 Valencia Blue
Stag Red
Jensen Interceptor MK1 Ice Blue
The Blog to be found at http://standardtriumphcars.blogspot.com/
TR5 Valencia Blue
Stag Red
Re: Parts give away
Be warned there's two types;mikew wrote:and a plenum chamber grill
A pressed steel 'orrible thing. Fitted to the later cars, my wifes '74 Estate has one.
A cast aluminium grill similar to the Stag (but not chromed) my '72 PI Saloon has one
Richard
Compulsive PI'er
Compulsive PI'er
Re: Parts give away
Mike needs the pressed steel one, he gave me the cast alloy one which would not fit......much to his disappointment.
Like most of us he thought the alloy one looks much better.
Re: Parts give away
I have one of those - a reject from Kevin!CRAJ wrote:Mike needs the pressed steel one
(OK Kevin, I know it wasn't really a reject, just not needed !)
- kevinw
Re: Parts give away
...but it came in very useful, Mike (thanks for the loan). It is in very good condition as well.
Kevin
Kevin
Kevin Warrington
Re: Parts give away
Mike
I have found the plenum chamber greille and an OSR door checkstrap. Just the NSR one to locate and I will send them to you. PM me your address and I will advise when I send them.
Re: Parts give away
Thank you so much.Charles H wrote:Mike
Its help and support like this that makes me pleased to be a part of this club
mike
TR5 Valencia Blue
Stag Red
TR5 Valencia Blue
Stag Red
Re: Parts give away
All parts found and will be heading your way!
