Inner tie rod ball joints
Posted: Tue Jun 17, 2025 9:46 pm
by Binny
I’m just about to reassemble the inner ball joints on my PI after cleaning and checking the shimming.
Should the ball joints be packed with grease or just lightly greased? If mine were greased previously then it was all washed away by leaking PAS fluid over several years 😬
Thanks.
Re: Inner tie rod ball joints
Posted: Sat Jun 21, 2025 4:58 pm
by simon.williams
Which ones exactly? Are they on the track rods under the rubber gaiters? I’ve only ever replaced the outers. But I would suggest more grease better than less.
Posted: Mon Jun 23, 2025 8:19 am
by Binny
Hi Simon,
The inner ball joints where they bolt to the end of the steering rack. As it happens I’ve fitted them now and packed them with grease👍🏻
