Help with rear end noise
Posted: Tue Aug 06, 2019 12:56 pm
Hi all,
Haven't been on here for a while.
I am after some opinions on some rear end noise I am getting.
Once I get above about 65 I start to get a drone from the back end, which gets louder the faster I go but disapears if I take my foot off the throttle. Rear seems fairly quite below these speeds, not exactly silent but nothing you really notice.
I am thinking it is a worn diff but before I spend time & money searching for a better used one I was wondering if it could be anything else, perhaps quill shaft bearing? I have a new one of these and believe they can be replaced in situ after the diff and prop have come out (which I have done before to change the oil seals).
Background of car - 1972 2000 manual (non O/D) saloon with what I believe is the orginal 4.11:1 diff. Car now has 105,000 miles on it and I have done about 12,000 of them in the 6 years I have owned it.
Prop shaft was re balanced early on in ownership and one half shaft was swapped for another used one due to slight bearing noise - neither change made any noticable difference to the noise from the back although the prop re-balance did wonders for cutting vibration!
The noise has always been there and I wouldn't say it has got any worse but I don't do motorway speeds that often but I was carrying a passenger in the back down the M40 the other night and he thought the noise was hilarious as he couldn't hear our conversation in the back!
Any thoughts appreciated, plus also a line on a good diff if that is the way to go would be a help.
cheers
Chris
cheers
Chris
