Fueling too rich, 2.5 Pi
KieranEbbett2500
Hi all.
I've got a 1974 2.5 pi running a late green top MU. According to the previous owner it was rebuilt, the butterflys were calibrated and the rest was checked and was said to be ok. But the car in my opinion ran rich. I can confirm the MU had been off as it was spotless...
I am nearly finished rebuilding the engine( loads of new parts too many to list) and in the process removed a lot of carbon, more so than I expected. So I was really wondering what I can do short of sending the MU to the UK (I'm in new Zealand) and having it sorted. Apart from a higher fuel consumption than I would expect and slightly rich behaviour it ran extremely well and had a reasonable amount of poke.
Any help is appreciated
With all PI systems, it relies on vacuum to give accurate fueling.
Before you start with the MU, everything else must be perfect.
Ignition system, timing and valve clearances all need to be spot on.
Have you checked the vacuum via a gauge to find what hg reading you have?
KieranEbbett2500
Re: Fueling too rich, 2.5 Pi
Hi Alan
Well no I haven't. The engine isn't currently in the car so I can't check anything but I'll be striving to make sure everything is perfect. I don't have a vacuum gauge.
KieranEbbett2500
However what I checked of that (ignition timing, point gap and the rocker clearance was all as per the book.
Ok. Let us know when the engine is back in and running and we can guide you through some checks and tests. It's not that difficult and there are adjustments you can make to get it running correctly. Hopefully the MU won't need replacing.
KieranEbbett2500
Hi Alan.
Thanks for that. The engine is now reassembled and hopefully it'll be back in the car in the next few days.
According to the previous owner it was overhauled and set up on a test right by someone who was familiar with the Lucas injection system so I'm hoping it's not too serious.
I'm fairly sure there's someone in Auckland who can set up the units. Name escapes me at the moment though.
KieranEbbett2500
Hi.
Metering unit leaking fuel from tell tale hole upon running pump... bugger
That would suggest the seals need some work at the very least..................
KieranEbbett2500
Yep. Mustn't have liked sitting in the boot for three weeks too much. Must it be sent away now?
