Needle advice...
Posted: Mon May 25, 2015 4:19 pm
Good evening - I need some advice from you learned gents about what needle combo to put in my carbs...
I've got a 2500 engine from a MK2 PI which is running on HS6's with the GT6 style manifold. (standard cam) It also has a 6-3-1 extractor manifold and sports exhaust and K&N's. When I stripped the carbs down to repair the dreaded wax-stats leaking I found it had two different needles! It also has yellow springs I believe (for what it's worth...)
