Page 1 of 3
SAH rocker cover
Posted: Sun May 17, 2015 8:14 pm
by sahtuning2000
Tell me what i,am missing here or are they actually worth this much?????
http://www.ebay.co.uk/itm/triumph-rocke ... 33a2c54641
Re: SAH rocker cover
Posted: Sun May 17, 2015 9:00 pm
Can't see the attraction personally....I do like originality, I know, and as such I can't see the problem with the original rocker cover ....especially at that price!!
Posted: Sun May 17, 2015 9:05 pm
by sahtuning2000
Yeah but i can also see the attraction in having one if you don,t plan to use it like me!
Posted: Mon May 18, 2015 7:13 am
by englishbull
Nice but they not good on PI's..........
Posted: Mon May 18, 2015 11:14 am
by sahtuning2000
Is that because its difficult to attach the injector pipes to the top of the cover.
Posted: Mon May 18, 2015 12:34 pm
by englishbull
Heavier and height wise bigger than originals
Posted: Mon May 18, 2015 6:42 pm
by TedTaylor
Never had a real problem on my old PI, just needs to be removed carefully from under the injection pipes.
I also put sleeving around the pipes as they go over the cover to stop chafing and heat transfer.
The rocker cover gasket is fitted using the Range Rover method of sticking the cork gasket to the cover with evostick (I use spray stuff and a bit of masking) then thin smear of grease between gasket and head. Easy to re-use same gasket quite a few times as being cast aluminium puts even pressure on the gasket - just don't tighten up to tight, just enough to seal.
These covers are the ultimate bling
and I have one on Woody (bought from Italy) and was given one for AFH 20 years ago. Mind you there are the two that a couple of thieving b*st*rds from Bedford and Caister on Sea sold me but never delivered
MUT
Posted: Mon May 18, 2015 7:21 pm
by Dave B
Its the old story, they ain't making any more, and if you want one, here it is and this is the price. They have gone up quite a bit since I last saw one for sale, must be those TR chappies!
Posted: Fri May 22, 2015 9:12 am
by swifty
They are also good for anyone who wants to put a bling rocker cover on their Spit6/GT6 as there can be bonnet clearance issues sometimes if you use the more square TR6/2500 alloy rocker cover...
Posted: Fri May 22, 2015 11:46 am
by sahtuning2000
If anyone is seriously interested in buying one of these i would sell mine,i only have one and its not fitted to the car.
