Hi all,
I recently changed the bulbs in the 'all systems go' gauge on my '71 200 mk2 as only the indicators were left working. - Removing the front of the dashboard to do so. These now all work fine but the fuel gauge and temp gauge read out in the next dial along have started reading much higher than before. - Am 99% sure that the two issues are related.
Have I accidently pulled out an earth of some sort?
Any thoughts
Julian
Fuel and Temp gauge over reading
Julian B 1972
- Andy Thompson
Re: Fuel and Temp gauge over reading
Voltage stabiliser- little box thing with two terminals on the back of the speedo - controls the good health of gauge calibration - they fail eventually - worth checking it's all wired up but it might just have expired after 43 years
Perth WA
1970 2500PI estate
1964 2.7PI saloon
1973 2100 EFI Megasquirt
1972 Stag
Very Big garage
1970 2500PI estate
1964 2.7PI saloon
1972 Stag
Very Big garage
As Andy says!
Change it, you can get modern solid state ones which work very well, on eBay very cheap.
Julian B 1972
thanks both.
Much appreciated as always
Julian
Julian
Check that you haven't dislodged the earth wire on the stabilizer . Did it once with similar results.
