Page 1 of 2
main beam not working
Posted: Wed Dec 04, 2013 9:40 pm
by KellyTurner1990
Right. So one day, driving along in the dark down the country lanes I go to turn my main beam on and nothing. Darkness, little panic and just put the normal beam back on. The main beam works if I hold the stalk towards me, but push it back and it doesn't work. What is it most likely to be and what shoukd I take a look at?
Re: main beam not working
Posted: Wed Dec 04, 2013 10:15 pm
by Alec
Hello Kelly,
probably the dip switch, that's what I would look at first, if not then the side main light switch.
Posted: Wed Dec 04, 2013 10:20 pm
by Alan Chatterton
Definitely the main/dip switch. The contacts burn out. Getting scarce but usually turn up on eBay.
Known weakness.
Posted: Wed Dec 04, 2013 10:33 pm
by radders
I bet you didn't have relays fitted on the headlights?
Exactly the same happened to us on the Club Triumph 10 countries rally on Darren Sharp's Car.
Once you've replaced the switch, fit relays to take the current away from the switch otherwise you'll burn it out again.
Posted: Wed Dec 04, 2013 11:08 pm
by CAR
Fit the relays first and see if that does the trick, you may find (as I did with my pi) that the dipswitch is OK still.
Posted: Sun Dec 08, 2013 8:25 pm
by KellyTurner1990
Amaure here. Someone has mentioned this to me before. It sounds exatly like what has happed to.my beloved triumph.
So how do I fix this, new stalk?
Posted: Sun Dec 08, 2013 11:42 pm
by Charles H
Yep! Also put in relays to save the new switch going the same way!
Posted: Mon Dec 09, 2013 12:07 pm
by CAR
CRAJ wrote:Fit the relays first and see if that does the trick, you may find (as I did with my pi) that the dipswitch is OK still.
As previously posted.
By dipswitch I mean stalk, they are difficult to get hold of and why bother when you don't know for sure that you need one.
Posted: Mon Dec 09, 2013 12:57 pm
by KellyTurner1990
Right. Ok thanks guys. If I can't get hold of one quick enough. Where am.i best getting juice from to put a small on off switch dedicated to just the main beam and.it can go under the steering wheel somewhere x
Posted: Mon Dec 09, 2013 2:15 pm
by KellyTurner1990
