2000 or 2500 ?
steve28
2000 or 2500 ?
#1 Post by steve28 »
Im not that up on the big saloon engines but how can you tell the difference between them just by looking at them ?
steve
1971 2000mk2 auto wedgwood blue
1973 2000mk2 white
1973 sprint yellow
1979 1500se rbrr 08/10
1980 1500hl vermillion
1975 1500tc auto green
1972 toledo 2dr valencia and red oxide
1972 toledo 2dr brown (sold)
1977 datsun 100a f11 white
Andy Thompson
Re: 2000 or 2500 ?
#2 Post by Andy Thompson »
Not really - only external difference is bigger front harmonic damper and deeper sump. Engine number should work (and is a pretty safe bet in 95+% of engines but you can build a 2500 out of most 2000 blocks. The very skinny early Mk2 2000 head 3.3" is unlikely to work on a 2.5 unless its is very trick so thats a pointer.
2.5 Engines can be suffixed CR MG, MK (Oz 2.5TC) , MN or MM + CC, CF, CP, CR (TR6)
2000 Engines are ME and ML + HC KC KD KE KF KG (GT6 Vitesse)
http://www.triumphspitfire.com/enginenumbers.html
Perth WA
1970 2500PI estate
1964 2.7PI saloon
1973 2100 EFI Megasquirt
1972 Stag
Very Big garage
steve28
Re: 2000 or 2500 ?
#3 Post by steve28 »
I think the engine number starts with MM but will check tomorrow when its daylight.
steve
1973 2000mk2 white
1973 sprint yellow
twomanytriumphs
Re: 2000 or 2500 ?
#4 Post by twomanytriumphs »
Not sure if your asking for this much info, but the mk1 engines have the intake and exhaust manifold ports in a straight line. Not so sure on the later stuff, other than the 74 up TR6 engines have bigger ports spaced further apart I think. PI stuff might be different though.
Kyle
65 TR4 Green (first car)
70 GT6 Blue
67 2000 Green
Re: 2000 or 2500 ?
#5 Post by Mike Stevens »
Mk1/Mk2 heads are easy to tell the difference. Mk1 has the manifold side stud/nuts below the manifold, Mk2 are above and visible between the manifold face and the rocker cover.
MM sounds like a facelift 2500 then. Actually, 2000 and 2500 engines sound different, but that is a bit subjective!
CAR
Re: 2000 or 2500 ?
#6 Post by CAR »
Mike Stevens wrote:Mk1/Mk2 heads are easy to tell the difference. Mk1 has the manifold side stud/nuts below the manifold, Mk2 are above and visible between the manifold face and the rocker cover.
Mk1 has what looks like exposed pushrod tubes either side of the spark plugs too.
steve28
Re: 2000 or 2500 ?
#7 Post by steve28 »
this engine is in a car that ive got for spares recently, and it now ive found out its a p reg 2500 tc
there was no reg plates on it when i got it and the log book has been sent off as scrap,
it starts and runs but smokes so will want a strip down.
1973 2000mk2 white
1973 sprint yellow
