Sorry Alec, can't agree there!Alec wrote:
the line I'm following is that the battery is the main source of power rather than the alternator, Certainly battery voltage droops with load, droop being dependent on the load itself, hence the ballast ignition system as the voltage drops by a few volts on cranking (albeit drawing 100, or more amps.). At idle the alternator should be generating above nominal battery voltage and the increased load should not really impact the alternator as the battery should feed the load?
Things to try/think about.
1. What size pulley is on the alternator. If too small, it will run the alternator faster.
2. This fan - I assume it's rad cooling fan? Where is it wired in the system? The best way would be a direct connection from the battery (fused) via a relay to the fan. The current then comes directly from the battery rather than through the loom - it might be quite a current. Also see below about extra wire!
3. Luminition. This is the ignition thingy? How is it wired to the coil with the ballast resistor?
4. It might be interesting to short out the ballast resistor and see if that has an effect on the stalling. If not, it's not a coil thing.
5. Unplug the alternator and see what happens with the lights on. Again, perhaps giving some clues.
6. More when I can think of it!
As you have so many non-standard parts (all of which are a good idea and nothing wrong with them) it makes it a bit harder to think of issues.
BTW, when measuring voltages, try to measure across the battery. The loom wiring is not up to modern standards and there will be odd volt drops all over the place. In fact, I would be tempted to fit a wire DIRECT from the alternator output to the battery +ve. How many THICK brown wires are there in the connector on the alternator? Hopefuly 2, but if not, I would fit this extra wire, especially with the high output alternator.
I'll keep thinking....
