Page 2 of 2
Re: Radiator cap mod
Posted: Mon Jan 15, 2018 3:11 pm
by Clifford Pope
You mean there is a space between the top of the radiator and the underside of the bonnet, so the radiator could have gone about 2-3 inches higher if the filler had been fitted say on an elbow at the side with the cap level with the radiator top?
Posted: Mon Jan 15, 2018 4:28 pm
by Charles H
If you mean that there is a gap between the radiator and the front vertical panel, the UK cars are flush at that point. My Oz 1971 PI had this flush arrangement and a mechanical fan only, and did not have trouble even when in Darwin. That included the PI system!!
Posted: Tue Jan 16, 2018 12:24 am
by trolleybus
Alec wrote: Sun Jan 14, 2018 9:35 am
Hello Bernard,
"The supplementary is:- Apart from allowing clearance for the radiator cap is there another reason why the radiator has a space between it and the bulkhead?"
I don't understand what clearance you are talking about, can you explain further or show a picture?
Here is a photo of the gap I am taking about, it would appear it may not be on the UK cars it leaves about 12mm between the radiator and the front panel.
Posted: Thu Jan 25, 2018 9:00 pm
by torque2me
Is it an oem uk radiator with flanges for the factory fitting? At this stage of the game the rad could have been replaced a few times. Ditto the flanges. I let the radiator manufacturer/re-furb company of Unipart do my Stag radiator. The replaced flanges were not even close - whoever did it obviously had never used a straight rule in their life.
