Discerning lot, these Triumph owners, eh Kevin?...kevinw wrote:Didn;t know James Taylor was into Stags - always liked his music, though![]()
Paint Code
- Jonathan Lewis
Re: Paint Code
Jonathan Lewis
2.5PI Mk2
2.5PI Mk2
wild bill
Re: Paint Code
Kevin,the spade terminals you need are 4.8mm in size.If you have a problem locating them,give me a call,I'll drop some in the post to you.Good luck,Bill.
Bill Young
1967 MK1 2000 MSS8E
1971 minivan IUI1588
1967 MK1 2000 MSS8E
- kevinw
Re: Paint Code
Thanks, Bill - I needed to top up the wiring bits box, so got a bag of 50 terminals from VWP for pennies, really. Hopefully, I can now get Mr Lucas's ghost out of my boot!
Kevin
Kevin
Kevin Warrington
Re: Paint Code
Hi Kevin,kevinw wrote:The spade connectors are 4 and a bit mm, not the usual 6mm, so while I have thousands of the latter, it's an urgent order to Vehicle Wiring Products for a job lot of what is needed.
Actually, they are 3/16", (the 'usual' ones bing 1/4"). I have loads here, all crimp types. If you're stuck let me know and I'll pop some in the post....
Re: Paint Code
Hmm. I should have read right through the posts!Mike Stevens wrote:Hi Kevin,kevinw wrote:The spade connectors are 4 and a bit mm, not the usual 6mm, so while I have thousands of the latter, it's an urgent order to Vehicle Wiring Products for a job lot of what is needed.
- kevinw
Re: Paint Code
Thanks for the offers. Mr Lucas's ghost has now been evicted and with all the earth's properly bonded not only are all the lights equally bright on both sides, the flashers flash at the correct rate!
How very different to the wiring of the 2000 which is still as it left the factory - the lamp holders are still like new and its easy to tell the colour of the cable without resorting to a bit of switch cleaner to remove the dirt.
Kevin
Kevin
Kevin Warrington
