It started quite well (considering it hadn't been run for a couple of months) and drove smoothly and normally. Everything seemed to be going fine. I left the engine running just above idling (about 1500-2000 RPM) for about halk an hour. Everything was fine until I came to take it back to the garage.
It was then that the "stoneleigh problem" (as it has become known since it once stopped me from getting there) came back to haunt me. I thought I'd gotten rid of this.
A description of this would be a particularly bad misfire and lack of power which gets worse the harder you depress the accellerator, Easing off the accellerator seems to improve it slightly although by then it's hard to make much progress using only 1/3 throttle. Any attempt to use more will cause coughing and spluttering and loss of any engine power.
I originally thought this might be due to a weak spark so I have tried replaced the plugs, the coil, the distributor cap, the leads, every spade connector in the ignition circuit under the bonnet (some were quite corroded), the car also now has an Aldon ignitor (which it didn't used to have) and I cleaneed out the filter in the glass-domed fuel pump but still this problem comes back whatever (and disappears just as quickly), again and again - without warning.
could it be something to do with grounding of the distributor baseplate (which might explain why it's worse under heavy throttle, as that's when it'll moves?).
I wondered if anyone has any ideas about this one? I'm running short just now and it's very frustrating.
Either this is a much more complex problem or I am missing the point entirely.
Regards
Daryl.
