poppyman
#41 Post by poppyman »
Hi Alec, yes checked with dwell meter all items fitted have been checked and all items replaced for a second time off a good running car. I must be missing something somewhere.....
#42 Post by Alec »
Hello Tony,
did you try another king lead itself?
iani
#43 Post by iani »
Have you checked the security & condition of the engine earths? Perhaps a clean up & re-securing might be in order.
poppyman
#44 Post by poppyman »
One new set of leads complete and one set off another running car Alec.
poppyman
#45 Post by poppyman »
All the earths have been checked and cleaned Ian, even put jump leads on direct to the block as well.
poppyman
#46 Post by poppyman »
Hi gents, finally found the problem. when go 12volt with an inline ballast, you must remove the wire from the starter and replace it with another direct to the the coil... it then gives a spark when cranking.. Totally stupid idea!!
Bad running was down to weak mixture on back carb and running without the airbox. :( My Dolly will run happily without when needed.
Thank you all for your help, i am now sleeping much better...
Tony
Forkie
#47 Post by Forkie »
Glad you have finally sorted it :)
Forkie
#48 Post by Forkie »
Hopefully so will i be able to sleep when my issues are sorted :)
poppyman
#49 Post by poppyman »
Have you tried yours with and without airbox? mine ran terrible without.
Forkie
#50 Post by Forkie »
Yes apparently they are un-drivable without. My issue is lack of top end speed. I am fairly sure i have an autobox issue so is booked in for a complete overhaul soon.
