Channel Steel Weld on, Retaining Door Seal
Channel Steel Weld on, Retaining Door Seal, How do people fix these to there doors?
Drill through the frame and plug weld from inside
0
No votes
Mig tack weld the sides to the frame
0
No votes
Try and get a spot weld tip into the channel
0
No votes
Give up and rivet them on
0
No votes
Total votes: 0
Richard B
#1 Post by Richard B »
How do people fix these door channels to the doors?
Richard
Richard B
Re: Channel Steel Weld on, Retaining Door Seal
#2 Post by Richard B »
Picture courtesy of CW Website
Richard
#3 Post by Alec »
Hello Richard,
I have brazed these on when I replace them, but I expect few have an oxy/acetylene set as I have.
It is very thin section steel so using a mig would be very difficult I would think?
An alternative would be pop rivets, stainless being a better option than the usual aluminium. Due to its section the standard pop rivet gun will not go into the channel. In such circumstances I use a very short piece of brake line as a spacer. It is a bit fiddly but effective. Another way would be with self tapping screws?
Richard B
#4 Post by Richard B »
Hi Alec, thanks for the input.
I fitted them by plug welding through the door frame (where I had drilled the spots out). a few mig welds were added to the sides to secure the channel.
No I don't have oxy, I do have a spot welder but this would only have really worked with new metal in the frame.
Richard
