Overdrive question
Joe Wright
Overdrive question
#1 Post by Joe Wright » Fri Jun 19, 2020 6:30 pm
Hello everyone. I've got a 1973 2000, not sure what overdrive unit it has in it I'm afraid. Just wanted to know is it normal for it to take a while for the overdrive to lick in when the car is cold?
Works perfectly when the car is warmed up but not at all straight after start up? Is this normal?
Probably takes a mile or two to get it going. No major drama just curious.
Thanks in advance
Joe
Re: Overdrive question
#2 Post by tony » Fri Jun 19, 2020 8:50 pm
Suggest that you give it an oil change and see what happens .
#3 Post by johnnydog » Fri Jun 19, 2020 11:23 pm
Even just a check of the gearbox oil level, without a full oil change, topping if necessary, could well improve the overdrive engaging. A low oil level is one cause of sluggish engagement.
An A type overdrive tended to have a harsher and more sudden engagement, whereas the J type were more cushioned and arguably smoother.
#4 Post by Clifford Pope » Sat Jun 20, 2020 6:02 am
It's worth doing a proper oil change, and cleaning the filter.
Joe Wright
#5 Post by Joe Wright » Sun Jun 21, 2020 7:53 am
Great.
Thankyou ever so much. I will give it a go.
All the best.
Ronald
#6 Post by Ronald » Mon Jun 22, 2020 7:41 am
If it is a J-Type overdrive with the oblong, finned bottom plate (6 screws hold it in place) just remove it (after you have drained the transmission of oil , but beware of getting a faceful of oil when you you are doing that!) Take out the filter and clean it. Ensure the gasket is intact or make a new one, and reassemble. Not sure if the earlier A type overdrive with the circular bottom panel is the same.
Joe Wright
#7 Post by Joe Wright » Thu Jul 02, 2020 4:54 pm
Thankyou. Overdrive was looked at only a few thousand miles ago so I'm hoping its something straightforward
#8 Post by tony » Fri Jul 03, 2020 4:29 am
What grade oil are you using? Just a thought.
Joe Wright
#9 Post by Joe Wright » Tue Jul 07, 2020 6:53 pm
Not sure. I haven't had the car long so haven't changed the oil yet. It's going in on Thursday so I'm going to ask for an oil change GL4 I think I have to use and fot the filter to be cleaned out. Fingers crossed it makes a difference.
#10 Post by Mike Stevens » Fri Jul 10, 2020 8:13 am
The original oil spec was EP90 (as also used in the diff) but these days you tend to get EP80/90 which seems OK.
I wonder how you got on yesterday?
