Hi John - As you say, a little different to door card clips.johnnydog wrote: Mon Nov 25, 2019 11:13 am I will also check my used wood dash panels. Can you confirm that you want a 2000 panel - do you want to go back to the PFL or keep to a FL with the hazard light switch and seat belt warning lamp?
John
It would be great if you have some. Whilst you are are it a better surround and lever sock would be usefully well.
Yes I am looking for a Face Lift version. Mine has the hazard switch on the right and has no seat belt light. Is that a known version or has a previous owner just drilled a hole for the hazard switch in the PFL board?
