Hazard warning wiring
kennyd
#1 Post by kennyd »
Hello, my 1974 2000 was not fitted with Hazard warning facilities through the indicators, I have the correct switch for the car, In advance of fitting this can anyone advise me if appropriate wiring for the switch is easy to access and where ? regards Kenny.
Re: Hazard warning wiring
#2 Post by Mike Stevens »
If you look at the wiring diagram for a later car which has hazard warning lights as standard, then that should show you what to wire where.
I am intending to do this to my 1971 PI and so will be going through the same process very soon! I have obtained the correct mating connector (from an old, later wiring loom). This, spliced into the existing loom should give me the correct connections.
#3 Post by tony »
Basically simple and I'm no auto sparky. As Mike says, get hold of a suitable wiring diagram. I did my Spitfire using an old 2500 hazard switch that I had.
Phil T
#4 Post by Phil T »
Interesting.
I have a 1974 2000 with hazard warning, and they get used twice a year.
First time when I test for the MOT, second time during the MOT......
