I have acquired a Triumph 2000 Mk2 Saloon built Dec 1972.
I've been working through checking everything out as it's been sitting for 14 years in a garage!
Fitted a new battery and new fuel hoses as they were gone.
Cranks over nicely but no spark.
The coil has power and attaching a HT lead straight to it, give no spark.
I attached the + and - straight to the battery and tapped the - to simulate points and it gives out a VERY small spark.
I tried an old MG coil with the same test and it did the same, I believed this coil was OK (maybe not)
Am I testing it wrong?
I have also measured with an OHM meter and get the below:
+ to - = 1.6 OHM
- to HT = 5.02K OHM
+ to HT = 5.02K OHM
The ballast resister measures about 60 OHM but seems a bit erratic and initially started at 207 OHMS and slowly dropped., may just be poor connections? Is this correct?
All tests done without anything connected.
So is the coil dead? If so advise on the correct one?
Is the ballast OK? What spec is the replacement
Other issues
1) The fuel tank is half full, 14 years old petrol, is it dead? Where can I get rid of it?
2) One of the carbs is overflowing, have removed it and the piston was stuck, seems to have no oil, is it just a simple strip down? Are there rebuild kits?
3) The Rad fins in the brittle are just falling off, where can I get another, is this used on other cars? Is it worth just a re-core?
4) I notice in the fuse box area there is a white and green cable not connected. I can't see this in the electrical diagram, any idea what it is and where it goes to (if at all)
Also where is the best place for parts?
I'm hoping to get it running at little cost, but I suspect that won't be the case.
I also have acquired from him a Renown, its in a real state, so I thought I'd get this one running first.
Any owners in the Cambridge area, would be good to compare notes!
Many thanks for any help you can give!
