Trivial question about indicator repeater lamps
Re: Trivial question about indicator repeater lamps
#31 Post by Dave B »
englishbull wrote:
Clifford Pope wrote:Are all the styles handed left/right?
Yes and the drivers side are the scarcest to source.
If they are handed, and as said earlier, there are three different types (thin, thick & domed) then surely there would be six different part numbers, would there not :?:
I have absolutely no experience of these, in over 35 years of Triumph ownership I have never even changed a bulb in one !
TedTaylor
#32 Post by TedTaylor »
I know there are six, but there were apparently eight numbers because BL changed all their parts numbers to a different system during production of the Mk2 facelift :shock:
MUT
JimB
#33 Post by JimB »
willjan wrote:Would it be possible to make them in a slightly less brittle plastic,my last flat example,old stock purchased earlier this year, developed a crack after parking at home one night. :( very disapointing.
Bill.
Thermoplastics/thermosets degrade over time, so with NOS examples probably being at least 20 years old by now, I'm not surprised they're failing quickly once exposed to UV (the enemy of plastic) and thermal cycling.
If the Spares Group (must print off form and join!) does remanufacture, then a modern material will be much more durable.
murcod
#34 Post by murcod »
I'd certainly be very interested if any are manufactured. I have NOS for one side (LHS?), but the other side I'm still looking for something. :(
David
murcod
#35 Post by murcod »
David
