Molybdenum and the Wailing Diff
scooters
#1 Post by scooters »
No, it's not the title of a 1950's Bodice Ripper.
Like many Triumph owners my diff is flippin noisy. Now I was staying at Killin the other week and was doing some work on the car when this old giffer stopped for a chat. He'd had a couple of Stags, a TR6 and a 2000 in the past and he said that what he used to do was to put a Molybdenum based lube into the diff, the metal (for Molybdenum is a metal) revitalises the bearings and cogs, incidentally, he was a chemical engineer by trade and said that when he was in the army, they used to use Molybdenum a lot for so they could hear themselves think inside the Centurion tanks.
I've just ordered an old diff from ebay which I am going to rebuild to the best of my abilities - in the meantime I was thinking about lobbing some Moly into the current diff.
anyone used it before?
seems to be one of those 'lost' ideas like lead loading
CAR
Re: Molybdenum and the Wailing Diff
#2 Post by CAR »
scooters wrote: seems to be one of those 'lost' ideas like lead loading
What you mean that you can load a diff with lead?....only if it's shot though! :lol:
Sorry couldn't resist that!
Dad says that was called 'Molyslip', but he couldn't vouch for it's worth. It was said to coat the internals allowing the 'box or diff to run low on oil without immediate damage.
#3 Post by Alan Chatterton »
Molydeb whatsit is CV joint grease. Far to thick for the diff.
Molyslip is the product that used to be sold as "shuts noisy things up". (tried it on the kids, doesn't work!)
Tried it on a whining diff years ago, doesn't work there either!
If the diff whines, its because its buggered. Fix it, or get another one!
leesellars
#4 Post by leesellars »
Hi friends
Bolts up is used for the propshaft and drive shaft slip joints
Triumph Mk2 PI 1975
Triumph TR6 PI 1973
murcod
#5 Post by murcod »
Do some research on Royal Purple oils - they make engine and gear oils that contain molybdenum.
I've never used it myself, but plenty of people rave about it.
David
scooters
#6 Post by scooters »
yes, but the idea is to shut it up a wee bit whilst I re build the 2500 diff I bought on ebay last week! not looking for snake oil - just a stop gap - the car is my daily driver afterall.
Thanks Murcon - I'll check out Royal
R
englishbull
#7 Post by englishbull »
Try these (advertise on Ebay) seems have had good results and a mate as used in his diff and was impressed.
http://www.lucasoil.co.uk/faq.php
