Wanted: 2500 exhaust system
dougusmaximus
Hi all,
I need a complete 2500 exhaust (except manifold) - anyone have one for sale before I shell out for a new shiny one ?
(South east / Surrey area )
Or can anyone recommend a supplier ? I've already found Chris Witor and Rimmerbros.
Doug
Doug
Last edited by dougusmaximus on Tue Jul 10, 2012 10:33 am, edited 1 time in total.
Re: 2500 exhaust system
Is the car manual or auto as it does make a difference.
colin
colin
dougusmaximus
Re: Wanted: 2500 exhaust system
Hi
It's actually for a Stag, in which I'm installing the triumph 2500 engine.
I think I'll need a 2000/2500 exhaust, and I'll need to shorten it by about 4-6".
I suspect that it won't matter too much if it's an auto/manual exhaust as I'll have to mangle it about anyway.
cheers
Doug
ps.
the alternative is to try to connect the engine to the standard Stag exhaust but there are many issues with that.
cheers
Doug
ps.
My PI Stag has the 2000 down pipe, a Y piece and then the standard Stag system. It is buggered though! If you do decide to go down the single pipe route and have the standard system 'spare', please PM me! If you would like to come and look at it, I am only just down the road near Folkestone.
What would be interesting to do would be a TR6 cast 6-2 manifold, then make up a link pair of pipes from the manifold flange onto a Stag standard system.
Richard
Compulsive PI'er
Daughters have Heralds. Son-in-laws have 2.5's
Compulsive PI'er
dougusmaximus
Yeah I looked into that. Sounds like a great plan, but Rimmer says the TR6 manifold alone is nearly £300 ! ouch .. I can't really stretch to that, but then a 2500 exhaust is about £250 anyway. Zoiks ..Richard B wrote:What would be interesting to do would be a TR6 cast 6-2 manifold, then make up a link pair of pipes from the manifold flange onto a Stag standard system.
I quite like the idea of a 2500 downpipe then Y piece to stag exhaust. How does it sound ? My stag used to be really quiet with the standard v8/exhaust so I'd hope if I connext the 2500 to the same system it'll be just as quiet.
did you make the Y piece yourself ? I don't know anywhere were I can buy bits like that.
Cheers for the suggestons !
by the way I like a quiet exhaust rather than "sporty".
d
dougusmaximus
Thanks !! I'll see how things pan out but it's likely at the end of it I'll have a very good stainless Stag system for sale. I'll let you know if it goes that way.Charles H wrote:My PI Stag has the 2000 down pipe, a Y piece and then the standard Stag system. It is buggered though! If you do decide to go down the single pipe route and have the standard system 'spare', please PM me! If you would like to come and look at it, I am only just down the road near Folkestone.
Did you make the Y piece (and presumably some extension pipe) yourself, or is there a place I can buy such thingies ?
hi mate,
i have a 2000 down pipe you can have if you want it, its in southend on sea essex though.
steve.
steve.
2 stags,2 tr6's,2 gt6's(all gone now) onto my 3rd mk2, i need all the help i can get
Hi doug im doing a stag at the moment with a straigt six in used original downpipe secondhand ss center section onto stag rear end double exhaust bit of fiddling between the 2 with odd bits of pipe made a 2 into 1 joiner so smoke comes out of both exhausts sounds ok not as nice as a v8 but i want a reliable rounaround, my mates also got a stag with a straight 6 in using 6 downpipe onto y piece and the rest stag he was at the national, that sounds nice,all depends on your budget really,
- Andy Thompson
TR6 Manifolds can often be picked up very cheaply - worth asking on TR Forum - I got two for 100 quid. Many have been replaced with expensive shiney bunches of bananas
Perth WA
1970 2500PI estate
1964 2.7PI saloon
1973 2100 EFI Megasquirt
1972 Stag
Very Big garage
1970 2500PI estate
1964 2.7PI saloon
1972 Stag
Very Big garage
