Im not that up on the big saloon engines but how can you tell the difference between them just by looking at them ?
steve
2000 or 2500 ?
2000 or 2500 ?
1971 2000mk2 auto wedgwood blue
1973 2000mk2 white
1973 sprint yellow
1979 1500se rbrr 08/10
1980 1500hl vermillion
1975 1500tc auto green
1972 toledo 2dr valencia and red oxide
1972 toledo 2dr brown (sold)
1977 datsun 100a f11 white
1973 2000mk2 white
1973 sprint yellow
- Andy Thompson
Re: 2000 or 2500 ?
Not really - only external difference is bigger front harmonic damper and deeper sump. Engine number should work (and is a pretty safe bet in 95+% of engines but you can build a 2500 out of most 2000 blocks. The very skinny early Mk2 2000 head 3.3" is unlikely to work on a 2.5 unless its is very trick so thats a pointer.
2.5 Engines can be suffixed CR MG, MK (Oz 2.5TC) , MN or MM + CC, CF, CP, CR (TR6)
2000 Engines are ME and ML + HC KC KD KE KF KG (GT6 Vitesse)
http://www.triumphspitfire.com/enginenumbers.html
Perth WA
1970 2500PI estate
1964 2.7PI saloon
1973 2100 EFI Megasquirt
1972 Stag
Very Big garage
1970 2500PI estate
1964 2.7PI saloon
1972 Stag
Very Big garage
Re: 2000 or 2500 ?
I think the engine number starts with MM but will check tomorrow when its daylight.
steve
steve
1973 2000mk2 white
1973 sprint yellow
1973 2000mk2 white
1973 sprint yellow
twomanytriumphs
Re: 2000 or 2500 ?
Not sure if your asking for this much info, but the mk1 engines have the intake and exhaust manifold ports in a straight line. Not so sure on the later stuff, other than the 74 up TR6 engines have bigger ports spaced further apart I think. PI stuff might be different though.
Kyle
Kyle
65 TR4 Green (first car)
70 GT6 Blue
67 2000 Green
70 GT6 Blue
67 2000 Green
Re: 2000 or 2500 ?
Mk1/Mk2 heads are easy to tell the difference. Mk1 has the manifold side stud/nuts below the manifold, Mk2 are above and visible between the manifold face and the rocker cover.
MM sounds like a facelift 2500 then. Actually, 2000 and 2500 engines sound different, but that is a bit subjective!
Re: 2000 or 2500 ?
Mk1 has what looks like exposed pushrod tubes either side of the spark plugs too.Mike Stevens wrote:Mk1/Mk2 heads are easy to tell the difference. Mk1 has the manifold side stud/nuts below the manifold, Mk2 are above and visible between the manifold face and the rocker cover.
Re: 2000 or 2500 ?
this engine is in a car that ive got for spares recently, and it now ive found out its a p reg 2500 tc
there was no reg plates on it when i got it and the log book has been sent off as scrap,
it starts and runs but smokes so will want a strip down.
1973 2000mk2 white
1973 sprint yellow
1973 2000mk2 white
1973 sprint yellow
