WANTED PI rear plastic number plate surround in exc cond
as the title says im after the pi trim behind the numberplate on the back panel
must be in exc condition thanks
- TedTaylor
Re: WANTED PI rear plastic number plate surround in exc cond
If it's the black ridged/corrugated piece of black plastic I've got a good one on the Sad PI. No cracks, scratches, holes (apart from number plate screws). Have not tried to take it off so hope it removes OK.
Problem is getting it to you without damaging it.
Ted
Ted
hi yes thats the one how much would you want for it including postage im sure it would be ok in bubble wraped in a box
thanks rob
- TedTaylor
Just the p&p will do.
I'll pop it off tomorrow and see how it can be posted - for safety needs to have some firm backing (cardboard, or masses of bubble wrap which I don't have) or it may get broken in the post.
Will PM you.
Ted
Will PM you.
Ted
hi any luck with the pi rear infill cheers
- TedTaylor
Safely removed - where do I send it? Will package it between some cardboard.
Ted
Ted
