I'm very pleased to say that my Pi has passed it's MOT today
I had to do a fair bit of work on it though, as it failed the first test on quite a few problems.
One of which was the front springs. As they were a bit low, and too close to the bump stops. This has raised the front about 3/4 of an inch, and makes a big difference to look at.
Here's a photo of the new spring in place:
I also fitted a non-return valve to the fuel line. This is supposed to prevent un-filtered fuel from going back to the pump when the ignition is off. And also to keep a good fuel line pressure for re-starting the engine.
Here's a photo of it to the right of the fuel pump:
I have managed to source a company that specialises in filters. They're 'In-line filters' based in Cornwall, and they do a very good web service, and deliver the next day.
I specified a filter that I could see into(to see if it needs changing), and of a high flow nylon type.
Here's some photos of the filter fitted to Pi:
And one loaded with rust from Pi tank:
You can see how small and useless the original Billet filter was compared to the bigger nylon type that is more suited to a big fuel injection system:
The lower filter is a longer higher capacity filter for longer service. So far i'm very impressed with these filters which have saved me from a load more problems with suspect fuel.
As I have to change the filters frequently(at the moment) I have made a bowl to catch the bit of fuel from the used filter, and put into a can in the boot. This works quite well when you have to change the filter on the road somewere, some times in busy towns for example:
I've taken a few shots of my Pi back home after the MOT today:
I'm now looking forward to the Triumph day at Duxford. I shall travel up with a few filters in the boot I think
